The celestial geometry is quite favorable this month for North American New Moon spotters. The ecliptic at sunset will be nearly vertical and the Moon will be north of the ecliptic. The Moon will also be near perigee, which speeds its angular movement from the Sun.
Geocentric conjunction between the Moon and the Sun in ecliptical longitude will take place on 2007 APR 17 at 11:36 UT. With extraordinary luck and skill someone in North America may spot the Moon that same day. To do so with naked eyes would be a near miracle.
I’ve created graphics previewing the western sky as seen from northwest suburban Chicago 25 minutes after sunset on 2007 APR 17 & 18. Although they should reasonably serve most North American observers. To see them, click: http://www.curtrenz.com/astronomical.html
In my graphic for the 17th the Moon is aged 13.4 hrs, while its apparent disk is illuminated by 0.5% and is elongated from the Sun by 7.9°. That is scarcely beyond the theoretical Danjon limit for detecting the Moon of about 7°. At the time and place noted in the graphic the Moon will be at azimuth 290.0° and altitude 2.8°. The ultra-slim crescent will appear less of an arc than a semi-circle, and in a “U” position that is somewhat unusual outside of the tropics.
In my graphic for the 18th the Moon is aged 37.4 hrs, while its apparent disk is illuminated by 3.6% and is elongated from the Sun by 21.7°. It should be easily spotted by North Americans with clear skies. At the time and place noted in the graphic the Moon will be at azimuth 285.3° and altitude 15.9°.
Happy New Moon Hunting!
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
