I was able to observe Comet Neat Q4 again this evening through my Celestron 7x50mm binoculars and have recorded my impression of what I observed. The observation was made at 01:30 U.T. on May 15, 2004 (or 09:30 P.M. EDT on May 14, 2004). Comet Neat Q4 appeared as a brightly condensed "fuzzball" with what appeared to be a tail in the southwestern (SW) direction (I have enhanced the appearance of the tail slightly for descriptive purposes). The cluster M44 (Beehive) was visible 2 degrees 19 minutes 03 seconds from the comet at this time. The closest bright star to the comet, in a SE direction, was Theta Cancri (SAO 97881, 5.3m). I estimated the length of the tail to be nearly 3 degrees (as this is the angular distance between the comet and Delta Cancri (SAO 98087, 3.94m) towards the SW). Tomorrow night (May 15, 2004) the comet will be approximately 1.5 degrees from M44. That will be a spectacular sight! I hope that you enjoy my observation.
The best of luck in your own imaging and observations of this comet.
Carlos
Carlos
