james carter
North American Nebula NGC7000
FYI -Next sunspot cycle will be 30-50% stronger
Started by RUSTY845, 03/10/2006 01:21AM
Posted 03/10/2006 01:21AM Opening Post
"This appears to be VERY GOOD NEWS regarding the next two sunspot cycles. Start getting your gear ready!"
2006-5 FOR IMMEDIATE RELEASE: March 6, 2006
Scientists Issue Unprecedented Forecast of Next Sunspot Cycle
David Hosansky, NCAR Media Relations
303-497-8611
[email protected]
Mausumi Dikpati, NCAR High Altitude Observatory
303-497-1512
[email protected]
Peter Gilman, NCAR High Altitude Observatory
303-497-1546
[email protected]
BOULDER—The next sunspot cycle will be 30-50% stronger than the last one and begin as much as a year late, according to a reakthrough forecast using a computer model of solar dynamics developed by scientists at the National Center for Atmospheric Research (NCAR). Predicting the Sun's cycles accurately, years in advance, will help societies plan for active bouts of solar storms, which can slow satellite orbits, disrupt communications, and bring down power systems.
The scientists have confidence in the forecast because, in a series of test runs, the newly developed model simulated the strength of the past eight solar cycles with more than 98% accuracy. The forecasts are generated, in part, by tracking the subsurface movements of the sunspot remnants of the previous two solar cycles. The team is publishing its forecast in the current issue of Geophysical Research Letters.
“Our model has demonstrated the necessary skill to be used as a
forecasting tool,” says NCAR scientist Mausumi Dikpati, the leader of the forecast team at NCAR’s High Altitude Observatory that also includes Peter Gilman and Giuliana de Toma.
-----Understanding the cycles -----
The Sun goes through approximately 11-year cycles, from peak storm
activity to quiet and back again. Solar scientists have tracked them for some time without being able to predict their relative intensity or timing.
Forecasting the cycle may help society anticipate solar storms, which can disrupt communications and power systems and affect the orbits of satellites. The storms are linked to twisted magnetic fields in the Sun that suddenly snap and release tremendous amounts of energy. They tend to occur near dark regions of concentrated magnetic fields, known as sunspots.
The NCAR team’s computer model, known as the Predictive Flux-transport Dynamo Model, draws on research by NCAR scientists indicating that the evolution of sunspots is caused by a current of plasma, or electrified gas, that circulates between the Sun's equator and its poles over a period of 17 to 22 years. This current acts like a conveyor belt of sunspots.
The sunspot process begins with tightly concentrated magnetic field
lines in the solar convection zone (the outermost layer of the Sun’s interior). The field lines rise to the surface at low latitudes and form bipolar sunspots, which are regions of concentrated magnetic fields. When these sunspots decay, they imprint the moving plasma with a type of magnetic signature. As the plasma nears the poles, it sinks about 200,000 kilometers (124,000 miles) back into the convection zone and starts returning toward the equator at a speed of about one meter (three feet) per second or slower. The increasingly concentrated fields become stretched and twisted by the internal rotation of the Sun as they near
the equator, gradually becoming less stable than the surrounding plasma. This eventually causes coiled-up magnetic field lines to rise up, tear through the Sun's surface, and create new sunspots.
The subsurface plasma flow used in the model has been verified with the relatively new technique of helioseismology, based on observations from both NSF– and NASA–supported instruments. This technique tracks sound waves reverberating inside the Sun to reveal details about the interior, much as a doctor might use an ultrasound to see inside a patient.
-----Predicting Cycles 24 and 25 -----
The Predictive Flux-transport Dynamo Model is enabling NCAR scientists to predict that the next solar cycle, known as Cycle 24, will produce sunspots across an area slightly larger than 2.5% of the visible surface of the Sun. The scientists expect the cycle to begin in late 2007 or early 2008, which is about 6 to 12 months later than a cycle would normally start. Cycle 24 is likely to reach its peak about 2012.
By analyzing recent solar cycles, the scientists also hope to forecast sunspot activity two solar cycles, or 22 years, into the future. The NCAR team is planning in the next year to issue a forecast of Cycle 25, which will peak in the early 2020s.
“This is a significant breakthrough with important applications,
especially for satellite-dependent sectors of society,” explains NCAR scientist Peter Gilman.
The NCAR team received funding from the National Science Foundation and NASA’s Living with a Star program. NCAR’S primary sponsor is the National Science Foundation. Opinions, findings, conclusions, or recommendations expressed in this publication do not necessarily reflect the views of the National Science Foundation.
Find images on the Web at
http://www.ucar.edu/news/releases
Bob
R.A.C. Advisory Committee
NEAIC Co-Chairman
NEAF Advisory Committee
Warwick, New York
41.15984 -74.2541
[B]Takahashi MT 160
10" F4.5 Newt 8O
R200SS grin
Some kind of 127mm APO
Orion Atlas EQ-G
Losmandy G11 with Gemini
iOptron Mimi Tower
iOptrom Cube Pro
Meade DSI PRO II 8O
SBIG ST-10ME
Image Source 21AU04.AS
