Good-bye to Venus Contest
Started by curtrenz, 07/23/2007 03:50PM
Posted 07/23/2007 03:50PM Opening Post
Who will be the last to spot Venus after sunset during its current evening apparition? It is becoming noticeably lower in the western sky at dusk each evening. Its apparent angular size is growing as it comes closer to Earth, while it dims as its crescent narrows.
Next month Venus will pass between the Earth and Sun in inferior conjunction. Here are the hours I’ve calculated for that event by three different definitions.
IC by Right Ascension: 2007 AUG 16 at 10 hr UT
IC by Elongation: 2007 AUG 17 at 20 hr UT
IC by Longitude: 2007 AUG 18 at 4 hr UT
At inferior conjunction Venus will appear to pass 8.0° south of the Sun. That will cause it to disappear even more rapidly from the evening sky for northern hemisphere observers. But it is possible that southern hemisphere observers will be able to spot Venus as both an evening and morning star during the night of August 16/17.
Please reply to this thread with descriptions or photos of your final post-sunset observations of Venus during the current evening apparition. Be sure to note whether you observed by telescope, binoculars or naked eye. We can make it a contest to learn who will be the last Venus spotter for each category. Daytime observations are discouraged due to the danger of peering at the Sun.
I’ve created a graphic that demonstrates the position of Venus in the western sky at dusk. It can be seen on my website. Next month I will post a graphic for the coming morning apparition in the pre-dawn eastern sky. My graphics can be seen at: http://www.curtrenz.com/astronomical.html
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
Posted 07/27/2007 04:21AM | Edited 07/27/2007 04:22AM #1
Here are my calculated data for angular size, percentage illuminated and stellar magnitude of Venus for the coming evenings at 21:00 CDT. grin
JUL 27 -- 47.7" -- 12.7% -- -4.3
JUL 28 -- 48.4" -- 11.9% -- -4.3
JUL 29 -- 49.2" -- 11.0% -- -4.2
JUL 30 -- 49.9" -- 10.1% -- -4.2
JUL 31 -- 50.6" -- 09.3% -- -4.1
AUG 01 -- 51.3" -- 08.4% -- -4.0
AUG 02 -- 51.9" -- 07.6% -- -4.0
AUG 03 -- 52.6" -- 06.9% -- -3.9
AUG 04 -- 53.2" -- 06.1% -- -3.8
AUG 05 -- 53.8" -- 05.4% -- -3.7
AUG 06 -- 54.4" -- 04.7% -- -3.5
AUG 07 -- 54.9" -- 04.1% -- -3.4
AUG 08 -- 55.5" -- 03.5% -- -3.3
Curt Renz
Posted 07/29/2007 04:45AM #2
Hrer's a photo of venus from the 24th a crescent with tons of atmospheric diffraction, it may be the last i see of venus this season.
Tommy5's attachment for post 115678
Posted 07/31/2007 03:23AM #3
I caught venus this evening 7-30-07 naked eye and then with binoculars at 8;30 cdt and it showed a delightful crescent in the bino i'll try to get a photo tomorrow if i can.
Posted 08/04/2007 01:39AM #4
Curt,
Thanks for the challenge, but it seems I am already out. I last saw her July 25th, and THOUGHT I saw her the 27th.
With the hazy, lazy, crazy days of August here in the midwest, the sun is a red ball setting and rising. The horizon has that gray look all day long. If past years are a hint, this could last several weeks. We need a good cold front to move through and clear all the haze out of here.
Venus was SO bright only a ten days ago, now I can't even find her with 10X50 binoculars.
Regards,
Rick W
8" Zhumell Dob
90mm f11 achro refractor
Posted 08/06/2007 08:24PM #5
Sorry about the lateness of my post, but I just noticed your little contest. Here's an image I took On July 30, and an excerpt from the text of the email I sent to my fellow club (see my profile) members:
Here's an image I took of a thin, crescent Venus tonight from my front yard, just as the sun was setting. If you haven't seen Venus this large and thin then you'd better hurry as it's quickly heading west towards the sun. Once it reappears in the morning sky it will still show a thin crescent, but it will quickly become smaller in diameter and more fully illuminated.
I took the shot through my 6-inch f/4.5 Newtonian RFT
"Smurfette", using my Nikon Coolpix 800 digital camera mated to an 8mm Tele Vue Radian eyepiece. Due to Venus's low altitude the atmospheric seeing was not very good; this was the best of many attempts. Once Venus moves into the morning sky I hope to get some better shots as the ecliptic ought to be at a much more favorable angle, plus I should be able to track it well past sunrise.
Here's some additional info on the image:
Time image taken: 8:56 EDT
Altitude: 7.4 degrees
Magnitude: -4.4
Diameter: 48.9"
Illumination: 10.1%
djscobel's attachment for post 115901
