Jupiter and Saturn 10-22-02
Started by Walter, 10/22/2002 11:39AM
Posted 10/22/2002 11:39AM Opening Post
Got up earlier than usual this AM so drug out the 8" f/6 dob and had a look. Wow! Saturn especially was very nice. 5 moons readily visible with no searching required at all. The planet disc had main equitorial band and the southern(?) area was broken up into fine details that were much more obvious than usual. Cassini visible all the way around, crepe ring obvious, and at 200x the outer ring "looked" like it wanted to break up a little (Encke minima?)
Swung over to the Trapezium and bingo, all 6 components were standing out like sore thumbs.
Jupiter was great as well, with the GRS pale but readily apparent. One moon was just getting close to the planet, either to be eclipsed or transit. Haven't checked the charts yet to determine which, but the moon's disc was very crisp and clear!
I've been considering getting a 4" refractor for supposedly fine images but I'm about to ask. "why bother?"
Walter
Posted 10/22/2002 06:43PM #1
Walter,
I had a similar experience a few days ago while it was still clear in SC. We usually have terrible seeing, the only time the air seems to get stable is when there is light morning fog which scatters some light. I had left my 10" F6 newtonian out on the deck to stablize for a few hours, then set it up around 4:30 and observed until dawn. The views were similar to what you described, except the GRS was on the far side of Jupiter. The highlight was watching Io and Ganymede pass each other just 2" apart. The huge difference in diameter was obvious between the two at high power. The seeing got better as twilight crept in and eventually washed out the finer details on Jupiter and Saturn. Hopefully the weather will clear up here soon so I can get some more viewing in.
Clear Skies,
Joplin
Posted 11/09/2002 08:52PM #2
Ken,
It is almost always the case if you are not ready to drop well over $1000 for one of the better made refractors, then you are better off with your reflector or even a SCT. Please note, in my book better made does not mean APO. I've owned several D&Gs and Jaegers achromats that proved to be superb. I've also owned two Synta scopes and while some folks claim to have excellent units, I have yet to see one that comes even close to the achromats I've owned (and I've seen plenty of Synta scopes).
With regards to your particular scope like Tony said we need to know more details before we can be of help. In more than a few cases collimation has been off with little you can do about it unless you have one of the newer lens cells with collimation screws.
Regards,
Angel
