Jupiter Observation (April 22, 2004)
Started by Martian, 04/23/2004 07:12PM
Posted 04/23/2004 07:12PM Opening Post
I made a Jupiter observation under average to good seeing conditions (6-7/10). Much detail was noted especially between the SEB and NEB. I welcome any comments on my observation.
Date (U.T.): April 22, 2004
Time (U.T.): 04:45
L1 133.8, L2 350.6, L3 290.6
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 258x and 388x
Filters: None (IL)
Seeing (1-10): 6-7, Antoniadi (I-V): II-III
Transparency (1-6): 4-5 (hazy)
Notes:
South Polar Region (SPR): Appears dark to dusky (3-4/10) and mottled.
South South South Temperate Zone (SSSTZ): Appears thin and bright (7/10).
South South South Temperate Belt (SSSTB): Appears thin and dull (5/10).
South South Temperate Zone (SSTZ): Appears thin and bright (7/10).
South South Temperate Belt (SSTB): Appears thin and dull (5/10).
South Temperate Zone (STZ): Appears thin and bright (7/10).
South Temperate Belt (STB): Appears dark to dusky (3-4/10) and broad.
South Tropical Zone (STrZ): Appears bright (7/10) and it contains a thin, dull (5/10) band across it's center.
South Equatorial Belt (SEB): Appears dark to dusky (3-4/10) with a thin, bright (7/10) zone across it's center (SEBZ).
Equatorial Zone (EZ): Appears shaded to bright (6-7/10) with dull (5/10) projections extending from NEB-S festoons. Very bright (8/10) ovals are noted over it's northern half between festoon bases.
North Equatorial Belt (NEB): Appears dark to dusky (3-4/10) containing bright (7/10) rifts within. A dark (3/10), "hook-like" projection is noted along the northern border (NEB-N) preceding the CM containing a very bright (8/10) oval. Very dark (2/10) festoon bases are noted along the southern border (NEB-S). A bright rift appears to extend from the NEB-N into the center of the NEB following the CM.
North Tropical Zone (NTrZ): Appears bright (7/10) and broad, but no other detail visible within.
North North Temperate Belt (NNTB): Appears thin and dusky (4/10).
North North Temperate Zone (NNTZ): Appears thin and bright (7/10).
North North North Temperate Belt (NNNTB): Appears thin and dusky (4/10).
North Polar Region (NPR): Appears dark to dull (3-5/10) and mottled.
The best of luck to you on your own imaging and observation of Jupiter.
Regards,
Carlos E. Hernandez
Martian's attachment for post 15242
Posted 04/23/2004 09:40PM #1
Great sketch, the neb is still unravelling and it is festoon city in the ez.you also show much detail in the north polar region,great work keep it up,send us more!
Posted 04/24/2004 11:28PM #2
Thank you all for your wonderful comments on my latest observation of Jupiter. I am glad that my observation was able to confirm many of the features in Mike's observation. Trying to record all that is visible over the jovian disk is not easy. The best of luck in your own observations.
Carlos
