Jupiter Observation (April 4, 2004)
Started by Martian, 04/04/2004 10:09PM
Posted 04/04/2004 10:09PM Opening Post
I made an observation of Jupiter this morning under average seeing conditions (5/10) with moments of 6-7/10. Detail was noted especially over the SSTZ/STB (including oval BE), EZ. and the NEB. I welcome any comments on my observation.
Date (U.T.): April 4, 2004
Time (U.T.): 05:15
L1 190.2, L2 184.2. L3 119.3
Instrument: 9-inch (F/13.5) Maksutov-Cassegrain
Magnification: 258x
Filters: None
Seeing (1-10): 5, Antoniadi (I-V): III
Transparency (1-6): 4-5
Notes:
South Polar Region (SPR): Appears dusky to dull (4-5/10) an mottled.
South South South Temperate Zone (SSSTZ): Appears thin and shaded (6/10).
South South South Temperate Belt (SSSTB): Appears thin and dusky (4/10).
South South Temperate Zone (SSTZ): Appears thin and shaded (6/10).
South South Temperate Belt (SSTB): Appears slightly broad and dusky to dull 94-5/10).
South Temperate Zone (STZ): Appears bright (7/10) following the oval BE complex.
South Temperate Belt (STB): Appears dark (3/10) with the very bright (8/10) oval BE surrounded by a dark (3/10) collar towards the preceding limb.
South Tropical Zone (STrZ): Appears bright (7/10) without any other detail visible within it.
South Equatorial Belt (SEB): Appears dark to dusky (3-4/10) with a thin, bright (7/10) rift (or zone) dividing it.
Equatorial Zone (EZ): Appears bright (7/10) with dull (5/10) streaks and very bright (8/10) ovals noted within it.
North Equatorial Belt (NEB): Appears dark to dusky (3-4/10) with a complex of very bright (8/10) rifts preceding and following the CM. Very dark 92/10) festoon bases are noted along the southern border (NEBs).
North Tropical Zone (NTZ): Appears broad and bright (7/10) with a very bright (8/10) bay noted along the NEBs preceding the CM.
North Polar Region (NPR): Appears dusky to dull (4-5/10) with a thin, bright (7/10) rift noted within it.
The best of luck in your own observations and imaging of Jupiter.
Regards,
Carlos E. Hernandez
Martian's attachment for post 14732
Posted 04/04/2004 11:48PM #1
Great sketch Carlos.have you seen the article on sketching Jupiter in the May issue of Sky and Telescope?You have nice detail on those festoons arching into the EZ,the big BE is well represented as is the big rift in the SEB,I think that rift was brighter last year but it is hard to compare simply from memory,anyway keep those reports coming thanks for sharing.
