Jupiter Observation (December 19, 2003)
Started by Martian, 12/20/2003 08:56AM
Posted 12/20/2003 08:56AM Opening Post
I made an observation of Jupiter under average seeing conditions (4-5/10) which revealed a good amount of detail over the jovian disk. The detail observed will be noted below. A very interesting and captivating sight was a double transit of Callisto and Ganymede over the northern hemisphere of Jupiter. Two dark shadows were noted floating across the North Tropical Zone (NTrZ) and North Polar Region (NPR). I welcome any comments on my observation.
Date (U.T.): December 19, 2003
Time (U.T.): 06:30
L1 249.7, L2 339.7, L3 246.4
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 206x and 281x
Filters: None
Seeing (1-10): 4-5, Antoniadi (I-V): III
Transparency (1-6): 2-3 (hazy)
Notes:
South Polar Region (SPR): Appears dusky to dull (4-5/10) and speckled.
South South Temperate Zone (SSTZ): Appears thin and bright (7/10).
South South Temperate Belt (SSTB): Appears dusky (4/10) and broad.
South Temperate Zone (STZ): Appears thin and bright (7/10).
South Temperate Belt (STB) Appears dark to dusky (3-4/10) with a bright (7/10) segment visible on the CM within it.
South Tropical Zone (STrZ): Appears bright (7/10) without other detail visible within.
South Equatorial Belt (SEB): Appears dark (3/10) with a thin, bright (7/10) zone dividing it. It's southern border appears irregular composed of dark condensations.
Equatorial Zone (EZ): Appears bright (7/10) with dusky to dull (4-5/10) projections originating from festoons along the southern border of the NEB.
North Equatorial Belt (NEB): Appears dark (3/10) containing small, bright (7/10) rifts and condensations within it.
North Tropical Zone (NTrZ): Appears bright (7/10) with the extremely dark (1/10) shadow of Ganymede (disk not visible) over the following half.
North Polar Region (NPR): Appears dull to dusky (3-4/10) with the very dark shadow of Callisto visible on the CM within it.
The best of luck on your own observations of Jupiter. May you all have Happy Holidays and a Happy New Year!
Carlos
Martian's attachment for post 11627
Posted 12/20/2003 02:00PM #1
Hi Carlos.
Great Sketch and written description. Happy holidays to to you.
Sol Robbins
Posted 12/21/2003 08:34AM #2
Sol,
Thank you for the compliment on my latest observation of Jupiter. The double transit was very interesting. As I was putting the scope away I noted the egress of Callisto and the Great Red Spot (GRS) on the following limb. That was spectacular as well. The best of luck in your own observations of the planets.
Carlos
