I was able to make an observation of Jupiter under average seeing conditions (5-6/10) with moments of 7/10. Much detail was noted across the jovian disk, especially over the SSTB/STB region, SEB, and EZ/NEB. The Great Red Spot (GRS) was visible over the following limb and was later timed at 091.6 (LII, or 010.6 LIII). I welcome any comments on my observation.
Date (U.T.): February 3, 2004
Time (U.T.): 06:15
L1 307.8, L2 046.9, L3 325.8
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 257x, 294x, and 386x
Filters: None
Seeing (1-10): 5-6 (moments of 7), Antoniadi (I-V): III
Transparency (1-6): 3-4 (Intermittent clouds)
Notes:
South Polar Region (SPR): Appears dusky (4/10) and mottled.
South South Temperate Zone (SSTZ): Appears thin and bright (7/10).
South South Temperate Belt (SSTB): Appears very thin and dusky (4/10).
South Temperate Zone (STZ): Appears very thin and shaded (6/10).
South Temperate Belt (STB): Appears dark (3/10) and broad.
South Tropical Zone (STrZ): Appears bright (7/10) with a small, dark (3/10) condensation visible south of the GRS.
Great Red Spot (GRS): Appears to exhibit a dark (3/10) southern border and core, dusky (4/10) material surrounding the core and bright (7/10) sections to the north (center timed at 091.6 (L2) or 010.6 (L3)).
South Equatorial Belt (SEB): Appears dark to dusky (3-4/10) with a bright (7/10) undulating rift within it, especially preceding the GRS.
Equatorial Zone (EZ): Appears bright (7/10) with very bright (8/10) ovals and dusky to dull (4-5/10) festoon projections visible within it.
North Equatorial Belt (NEB): Appears dark (3/10) to dusky (3-4/10) with small, shaded (6/10) rifts visible within. Very dark (2/10) festoon bases are noted along the NEB-S with dusky to dull (4-5/10) projections extending into the EZ.
North Tropical Zone (NTrZ): Appears bright (7/10) with no other detail visible within (including NTB).
North Polar Region (NPR): Appears dull (5/10) with a dusky (4/10) southern border and pole.
The best of luck in your own observations and imaging of Jupiter.
Regards,
Carlos E. Hernandez
Time (U.T.): 06:15
Filters: None
Notes:
Regards,
Carlos E. Hernandez
