Jupiter Sketch Feb. 8, 2004
Started by Sol R., 02/09/2004 06:03AM
Posted 02/09/2004 06:03AM Opening Post
Hi,
Had very good seeing conditions while observing with my 9.6" Newtonian. Magnification for this sketch was at 289x and Jupiter's image was very solid.
Of note was a large prominent oval. No guessing at seeing this one as its edges were well defined. Its rendered about half-way between the CM and the following limb in the SSTz. There were 2 other minor ones that appeared smaller and with less distinct edges.
The SEB rift appeared broken and gently sloped southward from the GRS toward the following limb. Fairly bright and well defined.
What was also striking was an unbroken dark rift in the NEB.
Starting near the CM it had a northward slope toward the following limb. There was also a lot of disconnected features appearing throughout the EZ with many appearing in the EZs.
Thanks, Sol Robbins
Sol R.'s attachment for post 13038
Posted 02/09/2004 09:19PM #1
Sol,
An excellent observation of Jupiter. The large oval over the STB is BE which is very prominent on many images obtained of the planet. Much detail is noted over the SEB and NEB. The GRS is notable on the preceding limb. Please keep up the good work.
Carlos
Posted 02/10/2004 07:40AM #2
Wonderful drawing.
I was observing Jupiter around this time (from NZ)in a IM 715 with the GRS near the centre I noted the spot is redder than i recall last year.
The seeing was'nt exactly stunning but the colour in the spot really stood out. The festoons and detail in the SEB(particularly close to the GRS)is very close to what I was seeing you've done a marvelous job of recording it.
I will try and toucam it this weekend willbe great to compare this with your drawing.
keep up the excellant drawings.
Phil B
Posted 02/11/2004 08:18AM #3
Here's a picture I made of more or less the same area of Jupiter on Feb 9. Very accruate drawing you have.
Dodi
Dodi's attachment for post 76194
