Mars 7.02.03
Started by Sol R., 07/02/2003 09:36AM
Posted 07/02/2003 09:36AM Opening Post
Hi,
I had relatively good seeing for Mars this morning. Mare Siremun, Eridania, Mare Cimmerium and Syrtis Minor were positioned well. Additionally, I could hold Electris visually from time to time. Hellas & Syrtis Major were following. I was lucky to get this drawing done before a cloud bank rolled in.
I also got to try a so-called new Mars filter. I believe this filter only allows the blues and greens, then attenuates or cuts out the yellows, then allows the oranges and reds. Basically, it is a notch filter with all higher transissions being in the 90-995 percentile. The attenuated notch is squashed down to around 10% or less. My take on this is that the overall tint/redition could be a little bit redder. I imagine that this beta filter will change a bit. This way the red features could appear redder and the dark features could be a little darker. This filter presented a slight greenish polar cap as well. I guess all I'm trying to say is that the green could be cut a little bit. My personal preference is to skip green image renditions when it comes to Mars. I have already been told the that notch will be moved about 15 nanometers toward the left-greenish end. I think that this may work out for the better. I'll report any progress that may be made regarding the possibility of any new interference filters.
Sol Robbins
Sol R.'s attachment for post 7325
Posted 07/02/2003 07:35PM #1
Hi Sol, I too was observing Mars this morning at about 4:45 pacific time and made this sketch with a TV-85 and 3.5mm Nag T6.
power_overwhelming's attachment for post 68856
Posted 07/04/2003 12:35AM #2
Sol,
An excellent observation of Mars showing much detail between Mare Cimmerium and Syrtis Major. The Mars filter is interesting and you bring out good points. Pease keep us updated on the filter in the future.
Carlos
