Saturn Observation (March 29, 2004)
Started by Martian, 03/29/2004 05:55PM
Posted 03/29/2004 05:55PM Opening Post
I made an observation of Saturn under good seeing conditions (6-7/10). Much detail was noted over the globe as well as the rings as evident in my observation. I welcome any comments on my observation.
Date (U.T.): March 29, 2004
Time (U.T.): 01:30
L1 325.2, L2 226.4. L3 092.3
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 258x and 388x
Seeing (1-10): 6-7 (moments of 8-9), Antoniadi (I-V): II
Transparency (1-6): 5-6
Notes:
South Polar Region (SPR): Appears dusky to dull (4-5/10) with a central dark (3/10) condensation surrounded by a shaded (6/10) inner collar.
South Temperate Band (STB): Appears dull (5/10) and wide with a slight greenish tinge surrounding the SPR.
South Tropical (or Temperate) Zone (STZ): Appears shaded (6/10) and broad without detail visible within.
South Equatorial Belt (SEB): Appears dark to dusky (3-4/10) and broad with dark (3/10) condensations noted along the northern and southern borders.
Equatorial Zone (EZ): Appears bright (7/10) with a thin, dull (5/10) band across the center.
Ring A: Appears shaded (6/10) with the Encke division (or minima) visible over the entire aspect of the ring.
Ring B: Appears bright (7/10) over it's outer half and dusky to dull (4-5/10) over it's inner half.
Ring C: Appears shaded (6/10) over the inner ansae and dull (5/10) across the EZ.
The best of luck in your own observations/imaging of Saturn.
Regards,
Carlos E. Hernandez
Martian's attachment for post 14530
Posted 03/29/2004 11:44PM #1
Carlos -
A beautiful drawing and very detailed observation report! The Encke Minima always peaks my curiosity. In images it appears as a low contrast darkening over a large portion of the A ring with the Encke Division at its outer boundary. But it is often drawn as you have it - a narrow band in the center of the ring - a seeming Encke division in a slightly different location.
Thanks for posting this excellent observation,
Alan
Alan Friedman
Posted 03/30/2004 12:58AM #2
Alan and Marc,
Thank you for your compliments on my latest observation of Saturn. I was fortunate to have observed under good seeing conditions.
The majority of Encke "Division" sightings are actualy those of the minima. Classicaly the minima is located over the middle of ring A and the division over the outer third of the ring. Good to excellent seeing conditions are required to observe this elusive division.
The best of luck on your own observations.
Carlos
