I made the following Saturn observation on November 26, 2003 at 07:00 U.T. I hope that you all like it. The best of luck on your own observations and images. I welcome any comments on my observation.
Date (U.T.): November 26, 2003
Time (U.T.): 07:00
L1 223.1, L2 162.0. L3 177.2
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 257x and 343x
Filters: None (IL)
Seeing (1-10): 5-7, Antoniadi (I-V): III-II
Transparency (1-6): 6
Notes:
The South Polar Region (SPR) appeared shaded (6/10) with a central dark (3/10), elongated core. The SPR was surrounded by a broad, dusky (4/10) collar. The region between the SPR collar and the South Equatorial Belt (SEB) appeared bright to shaded (6-7/10) with no detail visible within. The South Equatorial Belt (SEB) appeared dark (3/10) with a dusky (4/10) border to the south separated by a thin shaded (6/10) zone. The Equatorial Zone (EZ) appeared bright (7/10) with a thin, dull (5/10) belt (band) dividing it.
Ring A appeared shaded (6/10) with the Encke Minima visible over the ansae. Ring B appeared bright (7/10) with a thin, dull (5/10) division over it's outer half and the inner portion appearing dusky (4/10). Ring C (Crepe) appeared shaded (6/10) and somewhat transparent, except over the globe where it was prominent.
Regards,
Carlos
Time (U.T.): 07:00
Filters: None (IL)
Notes:
Regards,
Carlos
