Sketch of comet 2002T7 - 2/7/04
Started by skyrover, 02/10/2004 03:05AM
Posted 02/10/2004 03:05AM Opening Post
Here is a sketch from 2/7/04 of comet 2002t7, limiting mag 5.5, trans. excellent, temp -5F, 20cm newt / 30 mm plossl. Size of the eyepiece field is 1d 20m.
Note on the sketch - the comet was both larger and dimmer than the sketch shows, and the tail extended about another 40%. My original sketch shows this, but the scanner, or the scanning software has trouble capturing this level of detail. I'm working on the scanning technique to improve this...
Detailed observing report at the link below, including how to have fun with a laser and a stupid security light...
cheers, tim
http://www.skyrover.net/notebook/
Notebook of a Comet Hunter
skyrover's attachment for post 13065
Posted 02/10/2004 03:27AM #1
Hi Tim,
A very nice sketch. I wonder if you originally draw black on white rather than white on black. If you originally do it black on white and then use scanner features to produce a white on black image, try adjusting a feature knowm as gamma.
Some scanner do have the gamma feature and are usually have its setting defualted at 1.00. If you reduce this number to say, 0.85, the middle to dark tones become a bit more saturated. On my planet sketches, I have the gamma set at 0.67.
Again, a really nice sketch and hope that helps, Sol Robbins
Posted 02/10/2004 02:52PM #2
Thanks for the observation, Tim. I hope to get out and observe it this new moon cycle, if I get any clear weather.
My scanner is a cheap one also (Lexmark 73), but I can have it scan in color, B&W, and grayscale. I find that I get the best results in grayscale. I think that it's nearly impossible to get the relative brightness right, though. The eye has way more dynamic range than what one can capture on paper.
Thanks for sharing!
Doug Scobel
