VDB 142 Elephant Trunk HOO
The Galilean Triangle, 2004/2/16 UT
Started by Dave Mitsky, 02/16/2004 10:34AM
Posted 02/16/2004 10:34AM Opening Post
Although the transparency was far from ideal and the temperature was a frigid 12 degrees Fahrenheit, I nevertheless enjoyed observing at the ASH Naylor Observatory on Sunday night. The highlight was most definitely the close grouping of Io, Europa, and Callisto.
After viewing M78, M42 (six components of the Trapezium were seen), M43, NGC 1981, Saturn, NGC 2392, and Beta Monocerotis with the 17" f/15 classical Cassegrain at magnifications ranging from 162 to 259x I took a warm-up break. When I returned to the French Dome I was joined by three fellow ASH members. We searched for two of Saturn's more difficult satellites using magnifications of 381 and 404x.
Around 3:30 UT I slewed the 17" to Jupiter. The GRS was just past the CM and looked rather pale. Io, Europa, and Calliso formed a small triangle to the east of the planet while Ganymede orbited far to the west. With time the triangle flattened to a dogleg pattern.
One member stayed on with me. We had a look at M65, M66, Beta Monocerotis (a first for him), M78, and M42.
I took another break, a much longer one, and eventually returned to the dome to have another peek at Jupiter, going as high as 381x. I noticed what looked to be a white oval adjoining the NEB and to the west of the CM around 9:10 UT. By that time the Galilean triangle was just a slightly crooked line.
Dave Mitsky
Posted 02/17/2004 01:18AM #1
Great report Dave, you really have a wonderful chance to look through great scopes,do you think the grs is more pinkish or more prominent as some folks have suggested?
