A transit of Mercury across the Sun’s apparent disk will occur on Wednesday 2006 NOV 08. Mercury transits happen about 13 times per century (much more frequently than for Venus.) The last one was in 2003, and the next one following will be in 2016.
For those of us in Chicagoland, this year’s transit will be an afternoon event interrupted by the setting of Mercury beneath our horizon at 16:34 CST. The local exterior contact at ingress will occur at 13:12:25 CST and interior contact at 13:14:18 CST. Mercury will appear closest to the center of the solar disk at 15:40:53 CST. Although Mercury will have set before egress for Chicagoans, interior contact at egress will occur at 18:07:41 CST and exterior contact at 18:09:34. CST is UT - 6.
Except for the sunset time, the figures shown above should be correct within one minute for any location in sunlight (allowing for time zone adjustments.) If the Sun is up for you, and clouds are not intervening, you will be able to witness the transit.
I’ve created a graphic previewing the transit as it will be seen from Chicago. To see it, click:
http://www.curtrenz.com/astronomical.html
The graphic may be removed soon after the event occurs.
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
