Ghost of Cassiopeia
TV-102 detected Jupiter phase - fact or fiction?
Started by ronbee, 05/23/2003 07:04PM
Posted 05/23/2003 07:04PM Opening Post
My 4" TV-102 Light Cup seems to be in need of assistance yet again ;-). After seeing Mars' phase, I prosed a question about Jupiter and Saturn's phase. Indeed, the data shows that it would be extremely small. A couple of highly experienced observers gave me a tip to look for the difference in the brightness of the rim of the planet's
disc.
Last night, I observed Jupiter tonight with my 4" TV-102 APO and sketched it from 3:50-4:10 UT. The CM (System I?) was 147d. The seeing was betweenn II and III I believe. I could see that indeed the following rim of Jupiter is dimmer than the preceding rim, but nothing that could be all a phase. I would described it as dimmer whitish yellow than the planet's whitish yellow color. Checking with
my TheSky software, Jupiter has about 99% phase :-(. Here's my sketch.
http://members.cox.net/ronby/Planet-Sketches/Jupiter-052203.jpg
I used 220x (which the seeing could not support on the features) but it helped me with the "phase". Then, down to 176x for the rest of the sketch. The #12 filter seems to bring out the contrast and a strong impression of the difference between the brightness in the proceding rim vs the following rim.
It was quite difficult to convey the view with the sketch, adding to it my inexperienced sketching skill :-( Notice the very tiny gray "crescent" in the sketch at the following rim. The boundary in my sketch is actually imaginary and it was more gradual than the sketch could convey.
What do you think? Did the Light Cup show me phase detection fact or was the view imaginary fiction? Has anyone seen the difference in the brightness between both rims?
Very much obliged to any help I can get.
Ron B[ee]
Posted 05/23/2003 09:11PM #1
I'm hopeful for good skies, tonight, Ron. If they pan out, I'll give Big Jove a look-see and report back here.
Assuming you *did* see what your sketch conveys :-)
then I think you *did* see what you thought you saw. ;^)
And hey, at least you're sketching! I'm still slacking off, in that regard :-
Best wishes, and thanks for the update.
-Dan
Posted 05/24/2003 05:05AM #2
Well, Ron, my night sky was mostly clear, but the seeing was fair at best (moderately "thick" laminar flow). I thought I *might* have observed "something going on" along Jove's trailing limb, but it could just as easily have been illusory. Just too wide a margin for error.
I'll try again, tomorrow night.
Meantime, I'll set my alarm for 4am (MDT) and hope my southern vantage is clear and the seeing good. Around that then, Syrtis Major will be quite major indeed. Besides, Mars's 87% illumination will be a bit easier to discern :-)
Cheers.
-Dan
