Shane Yarnall
LDN 1622
45 seconds gone
Started by hakescl, 12/10/2008 03:20PM
Posted 12/10/2008 03:20PM Opening Post
I was previously getting glitches like this intermittently. Not all the time, but if they did happen, there seemed to be a periodicity (~5min). You can see where the scope misses tracking for a bit (looks much faster than sidereal when it happens, but it may not be). Anyway the autoguider puts it back on track in a couple of steps. Still very annoying.
But now it is fixed, as far as I can tell. At least I haven't seen it. I think it is ~20% from the upgraded balance and ~80%+ from tightening the RA belt. I could see on the teeth of the belt gear attached to the motor what looked like a screwdriver ding. I think the belt was ridding up and then would pop into the next slot. Tightening definitely fixed that, since I no longer hear a little click as the scope slews east. I had thought the "click" was normal. Must have been a manufacturing defect?
One more tiny step...
Charlie
hakescl's attachment for post 44870
Darkness - typically 6.5+
Focus - JMI Smart focus
Posted 12/10/2008 07:12PM #1
Hi Charles,
Good to see you have found the problem. Yes, if a cog belt was to skip a tooth, I guess it could look like that. I found my Meade LXD650 mount also had a very loose belt. It worked better after I tensioned it.
Posted 12/14/2008 03:06PM #2
Really glad to hear you found & fixed your issue... 8)
Posted 12/15/2008 03:48AM #3
Charles, congrats. It always feels nice to understand the cause of an annoying issue. Better yet when you have a fix for it.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
