Heart and Soul Nebulas
An answer to the Virtual Moon 4 issue
Started by fblue, 05/23/2008 07:31PM
Posted 05/23/2008 07:31PM Opening Post
Hello,
I got an answer from the author of the program, which I will post here. It seems that it uses a file which is also used by other programs, which he explains here.
So, it would seem that the file does exist, but is just a part of the install-uninstall and not a threat.
Floyd
Re: [virtualmoon] Question about Virtual Moon Atlas Ver 4 and Registry Clean Fix 2008 in the exe
[COLOR="Blue"]Hi,
I can ensure you there is no "addon" with VMA download.
This is not the first time some anti-virus or anti-spyware give false detection
on the installer software. This is generally due to poor filtering rule.
VMA use InnoSetup ( http://www.jrsoftware.org/isinfo.php ) to build the
installer package, the uninstaller part consist of the two files unins000.exe
unins000.dat which allow to cleanly remove the application.
But some spyware also use InnoSetup to install there sh... and then also install
this two files.
If the anti-virus maker do not take enough precaution when building it's rule it
can give you a warning because of this.
On the new web page the email address are mailbot protected, pch [at] freesurf
[dot] ch must be converted to pch@... smile
Patrick
[/COLOR]
Posted 05/23/2008 07:54PM #1
Good enough...
Thanks Floyd! 8)
