Best Focal Ratio for Imaging Under 4.5 Mag Skies?
Started by jsiska, 12/01/2008 05:49AM
Posted 12/01/2008 05:49AM | Edited 12/01/2008 05:53AM Opening Post
I've read in other posts that using an astrograph under light polluted skies doesn't work very well and that it is better to use a slower focal ratio under those conditions. What is the sweet spot in terms of focal ratio for CCD imaging under skies that are approximately 4.5 magnitude?
Jim
Posted 12/01/2008 04:42PM #1
Hi James,
While I have never used an astrograph I don't see why it would be better to use a slower scope in light polluted skies.The ccd is just counting photons whether they are in the form of light pollution or the object you are shooting.A faster scope should just mean shorter exposure times to get the same signal to noise.
I shoot in skies that range from about 4.5-6,depending on which direction I point my scope,there is always light pollution present in my subs sad
I have found more exposure time,better "signal to noise" helps to make it easier to deal with.
A fast scope would be ideal for narrowband imaging.
Jason
Posted 12/01/2008 05:04PM #2
James,
I don't recall reading or hearing that focal ratio has much to do with light pollution.
The object of the game is to gather light. The faster the focal ratio, the shorter the exposure time for extended objects (like nebula).
It is true that a faster focal ratio will gather light pollution more quickly than a slower one, and therefore equivalent exposures will show more light pollution with a faster scope. But the cure for that is to simply expose for shorter times. (Well, it is not a "cure" for light pollution.) One generally exposes for the value of the background sky. You are looking for that point at which the light pollution (skyglow) rises above the electronic and other noise. That is, when the light pollution starts to register (background sky glow rises to the perceptible---)stop the exposure.
What you are after is the difference between light pollution and other noise and the signal noise of your object. As soon as light pollution (skyglow) reaches electronic noise, you are at the point of diminshing returns. So, stop the exposure, and begin a new one.
You get to that point quicker with a faster focal ratio, but the signal and the noise rose at the same rates.
At least as far as I know.
Posted 12/01/2008 06:57PM | Edited 12/01/2008 06:57PM #3
Hello James, and thanks for bringing a great question to the forum...
What I'm going to say is simply MY OPINION, and nothing else, please take it with a grain of salt... 8)
Lets start with saying that for DSOs, nothing is better than truly dark skies...
I live under Mag 3.5-4.0 skies, and after much trial & error have decided, IMHO, that it really is not worth to image DSOs under these skies, unless these DSOs are very bright and located at the Zenith. The light pollution quickly fills up my CCD in such a way that any faint detail is washed up. (not to mention that the background gets lit up!)
If you plan on imaging Planetaries (small & very bright), or Star Clusters, you might be OK, but anything else is pretty much a very tough target. (For Planetaries, a Long Focal length scope is almost a "must have", which would certainly reduce the FOV to about what is needed for the Planetary alone, leaving much Light Polluted area out of it)
The only way, IMHO, to succeed at imaging LARGE DSOs, would be through Narrowband Imaging, which would get rid of all that LP.
Like I said, this is simply my opinion, so your mileage may vary...
Clear skies to you,
