Well, I have been doing some testing, the weather has not been good enough to image. So I decided to work on some issues.
I did a series of 15 x 10 minute exposures of M81. When I finished, I checked the frames and found that there was a steady drift from East to West. This amounted to about .9 arc minutes in 2.5 hours or about .0004 error ( or 3% error over 2.5 hours). But this did make a 5mm drift on a 160mm scale, so it is significant.
Now this would normally mean that the mount was running slow and should have the RA Divisor number reduced by about 22-23 to get the speed correct. However, the real question for me is, WHY is there any drift when guiding? I mean, the guiding should speed up or slow down the RA as necessary as it keeps the star in place, right? So, how does the mount drift in RA during guiding?
I have seen some elongation in the East/West direction for a while in exposures. I figured it was due to flexure, but have done a lot of mods to eliminate flexure, which I really did not think was the issue.
Now, if it were flexure, the mount was on the West side of the Meridian and the flexure would have caused the mount to lead (speed up) not lag (slow down), so the drift would be from West to East as the scope leaned toward the West which would cause the star to drift to the East, right?
So, what do you all think about this issue? Flexure just does not seem to be a possibility with this kind of drift. But, if it is the mount moving too slow, then wouldn't the guiding compensate? So, would this mean that the guiding program must be the cause? I am a bit confused to say the least.
I plan on going out and checking the speed with no guiding and see if there is indeed an East to West drift in the mount.
Floyd
Floyd
