First light image with 305 Honders Astrograph
Started by RolandC, 05/20/2009 07:05PM
Posted 05/20/2009 07:05PM | Edited 05/20/2009 07:06PM Opening Post
This is probably the first image ever taken with a Honders-type Cassegrain astrograph.
305mmF3.8 Riccardi-Honders Astrograph, 3600 Mount, MaximDL,
Camera STL11K, Baader H-a and OII combined as RGB, exposure: 9x10 minutes H-a and OIII
Image has been reduced to 1/4 size with full size crop at top right.
For those unfamiliar with Honders, it is a design derived from the Schupmann Medial telescope, invented more than a century ago. Klaas Honders modified the original design into a Newtonian configuration, and from there Massimo Riccardi developed it further into a Cass configuration. My design is a 305mm F3.8 Cassegrain based on the Riccardi-Honders configuration. The basic optical layout is a front positive lens followed by a smaller primary Mangin mirror, a secondary mirror (same as a normal Cass secondary) and finally a small single element field lens about 4" in front of the focal plane.
This astrograph features a very wide,flat, fully diffraction limited field of about 60mm diameter, with essentially zero chromatic aberration and perfect spherical correction for all colors. All surfaces are spherical, and the primary mirror has a second surface aluminized coating, something that will last essentially forever and will never sleek or weather because it is an inside coating not exposed to the air.
Rolando
RolandC's attachment for post 46919
Posted 05/20/2009 07:25PM #1
That's really outstanding Roland!
It would be a dream to have a scope like that! Who know if I ever will be able to afford it my lifetime!
Emanuele
www.backyardskies.com
Posted 05/20/2009 11:09PM #2
Wow - you could get lost in all that field. And f3.8 is quite the eye opener too.
So... it sounds like the light has to go "through" the glass on the primary? Or is that what you mean by "second surface?" If so, does that make 7 optical surfaces?! I guess it is easier if they are all spherical, but still quite an accomplishment.
Charlie
Darkness - typically 6.5+
Focus - JMI Smart focus
Posted 05/21/2009 01:37PM #3
Excellent!! I'm excited to get one and use it for dusty extended objects of low surface brightness. It should be great fun to use with a 16803!!
Tom
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
www.tvdavisastropics.com
Posted 05/21/2009 03:26PM #4
Hi Roland,
Wonderful image. Just wonder about the "affordable" comment though. Would that be "dedicated astronomer junkie" affordable... or "family treasurer" affordable!!! grin 8O grin
One serious question though. What processing steps did you just to get a RGB from just Ha and OIII? I am facing that situation myself as I am heading "down under" on Saturday for 5 weeks of observing, but have been unable to obtain an SII to go with my Ha and OIII.
Cheers,
Maurice
Posted 05/21/2009 09:15PM #5
Very cool wide field, looks flat and nice stars. smile
Posted 05/22/2009 07:22PM #6
Interesting thread, the Honders may have 7 optical surfaces, in reality my two fast Newtonians has 6! They will not work properly without the achromatic field flattener!
Nice wide image.
Joe.
