Fisrt Light Test of the AT65EDQ
Started by atalas, 01/31/2011 07:13AM
Posted 01/31/2011 07:13AM | Edited 01/31/2011 07:15AM Opening Post
Subject: First Light Test Results AT65EDQ
Hi Guys
Well I'm back from a dark site with my first test results of the AT65EDQ!
The test subject was a large emission nebula in the southern constellation of Carina called Eta Carina or, NGC 3372 If you would prefer.
To be fare to the little scope I'll be doing more test on It with better polar alignment because field rotation crept in on this night and because I needed to use and extender, I fear that the ccd chip wasn't quite flat to the plain....focus also a touch soft.
I want to also star test It to see how good the correction in the glass is,the collimation is and also If It has any(dare I say It)astigmatism which would be a real bummer.
Exposures were 10 minutes x 16 and flats,bias and bad pixel map were applied,pre processing done in AA4,Registar and post processing in CS4.
The StarlightXpress SXVF-M25c was used to capture exposures which were guided by a FS60CB on a GPDX/Skysensor.
The image can be found at my web site under most recent( www.atalas.net)
All thoughts would be appreciated.
atalas's attachment for post 52736
Regards
LouieĀ  8)
www.atalas.net
Posted 02/02/2011 01:29AM #1
Hi Louie!
The scope does show its potential with that shot! I'll be looking forward to a more thorough shake-down, but so far it looks like a winner!
Eric
Posted 02/11/2011 05:43AM #2
Louie,
The image looks pretty good. I can see from the larger image where you may have some critical thought on the results, but as I say, pretty good results.
I'd bet more on the tad soft focus and chip match to the image plane. I'm not sure I would say field rotation unless you see the rotation from frame to frame to frame. You may see the corner stars with the same shape in each image - if so that would not be rotation.
Also, I'm not 100% sure, but I think a larger chip on a smaller scope like this is very sensitive to the CCD being precisely flat to the image plane.
My 2 cents worth.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
