I've been searching for information on just what size guidescope is needed with modern CCD guiders. Everything I run across talks about double the focal length for visual guiding. Then I look at SBIGs website and see the e-finder for the STV. It certainly doesn't follow that rule. What I'm trying to do is this. I have a Vixen VC200L and a Celestron AS-GT, both "supercharged" by Dr Clay. I want to use my unmodified 300D for up to several minutes exposures. I can't fit much of a guidescope on that OTA mount combo, so I'm looking at options. Ideal would be the Atik line of B&W cameras or the new DSI Pro, but what about an LPI? What is the minimum focal length and aperture guidescope I could get away with? I'm guessing guide camera exposures should be kept under 5 seconds or so. Any suggestions?
Vixen VC200L: 200mm aperture, 1800mm fl f9
