Imaging from Upper Midwest at 2000mm + Focal Lengh
Started by Palomino, 02/09/2010 03:29AM
Posted 02/09/2010 03:29AM Opening Post
Hello all,
I am wondering if anyone is imaging in the upper Midwest (Wisconsin,Illinois,Michigan,Minnesota) at focal lenghts above 2000mm or more and getting good results on a relatively consistent basis. I image from the dark skies of far NorthEastern Wisconsin mainly with an APM/TMB 115mm F7, SXV-H9 and AP1200gto and have been getting good to great results for a little over two years now. Before that I did image with a 10" meade sct at F6.3 for a while, but results were inconsistent due mainly to frustrations with the scope and lousy tracking from the LX200 fork mount . I think from this experience I have been a little hesitant to drop alot of money for a quality longer focal lenght instrument even thought my mount problems have been solved since while seeing can be good at times here it's often very inconsistent. You can have a few nights of decent to good seeing and then nothing but garbage seeing for weeks or months at a time. I guess my ideal scope would be something like a 12.5" F8 RC or similiar, but Ive thought of getting something else in the 1500-2000mm range instead. Maybe a custom high quality astrograph of some kind? (suggestions welcome!) Suggestions on matching the right camera to scope wanted as well. The SXV-H9 would be one heck of a guider I would think along with being a great match for the APM/TMB 115mm F7
So, my question is, is there anyone out there getting consistent results at the above mentioned focal lenghts from the upper midwest. Or, will this venture be more trouble then it's worth? From my experience so far I think imaging at 1500mm or so is possible here, but Im really not sure about going over 2000mm from watching the skies here. Im just not sure the results would be good except for the few great seeing nights a year. It seems like here in the upper midwest when the seeing is good the transparency is bad and when transparency is good the seeing is bad or both are bad smile
Thanks for any advice
Mike
Posted 02/09/2010 06:12PM #1
Hi I have been imaging from Mi at 4500mm fl. I have found that if you shoot over water you can get very good seeing typ on a good night 1-1.5 arc sec, the worse I have had is 3.5 arc sec. The one thing I have noticed the stars don't twinkle out here. approx 60% of the time under 1.65 arc sec the rest 2.5 arc sec. When It's clear
jim
Posted 02/09/2010 11:49PM #2
I shoot from Rockford, Illinois, which is close to the Wisconsin border. You can look thru these deep sky images, which were shot from here using between 1000mm to 22,000mm focal length:
http://geogdata.csun.edu/~voltaire/roland/
I normally achieve 2 arc sec FWHM or better resolution here, and at times during the summer and fall as low as 1.2 arc sec FWHM resolution.
Rolando
Posted 02/10/2010 12:47AM #3
Hi Mike,
I am northwest of Chicago and I've been using a SXV-H9 for a number of years with an MK-809 Mak Cass at f\10 and f\8, around 2000mm and 1750mm with pretty good results. My seeing is typically in the 2" range. I just recently purchased a QSI 532 WS which has the same chip as the ST10-XME and the boost in sensitivity is very nice and has cut my exposure times significantly. You can see my images at my web site, the images with the QSI 532 are under the "New Images" link:
http://www.rwstanley.com/index.htm
Take care, Ron
