RICHARD COFER
VdB 141 Ghost Nebula
Lagoon Revisited
Started by jthommes, 06/03/2010 04:05AM
Posted 06/03/2010 04:05AM | Edited 06/03/2010 04:13AM Opening Post
All,
Richard Crisp had offered some advice on my recent posting of the Lagoon Nebula. I reprocessed accordingly (at least in principle). I used the RGB data stretched up to the H-Alpha levels as a color layer. I also combined the Ha data blended with blue under the color layer to help tighten up the stars on the RGB. I was a quick reprocess and there may be some artifacts, but a couple of things happend:
1. The little blue reflection nebula in the upper left now shows up. It was completely invisible in the earlier post.
2. The colors are quite a bit different - possibly a bit more muted but more natural?
The reprocessed image is here:
http://www.jthommes.com/images/M8_MN152_PS2RevA.jpg
For reference, the original image is here:
http://www.jthommes.com/Astro/images/M8_MN152_PS2_large.jpg
I think I like the reprocess color better. What do you think?
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 06/03/2010 12:27PM #1
I got that same lecture from Richard last year. (Thanks) This time, I want to make sure I understand your process details a bit better, so let me repeat back to you so you can correct my misunderstanding.
1. Make an RGB image with "correct" color balance.
2. Make an H-alpha image where the histogram "looks sorta like" the RGB.
3. In Photoshop, paste the Ha into the RGB (or vice versa) and it shows up as a new layer, so now you have two layers. (which on top?)
(Here is the part that gets fuzzy. Under blending options you can change the mode and opacity, and there are more check boxes if you open the blending options window...)
4. RGB layer: Set the blending option as "color", opacity 100%, arrange as bottom layer(?).
5. H-a layer: Open the blending style window and check only the "red" box. Set the blending option for Ha as linear dodge (add)?, opacity 50%?, other options?
6. flatten and repeat something similar for blue? Or can you just make a third layer and do this all at once?
Once you have completed your blend, flatten the image. Then can't you just goose up the saturation if the colors look washed out?
Thanks for any help here.
Charlie
Darkness - typically 6.5+
Focus - JMI Smart focus
Posted 06/05/2010 05:50PM #2
Yes, better. Great shot!
Tom
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
www.tvdavisastropics.com
