So, were you expecting an out of focus image?
Seriously though, last Saturday was first CCD light for my new (to me) Mewlon 210. I was all set to go with it and an AP 0.67 telecompressor in a JMI NGF-S. The focuser configuration was nearly identical to one that worked on my C8: SCT back (adapter in the case of the Mewlon)/NGF-S adapter/NGF-S/2"-SCT adapter/AP SCT-2" adapter/Telecompressor/2" nosepiece/CFW-8a/ST-8XE. I needed more in-travel.... :S
At the urging of my imaging buddies (I was at a friend's dark sky site), I removed the telecompressor and attached the camera directly to the NGF-S via the 2" nosepiece. I did this with trepidation, as I was not confident about tracking/seeing at 2415mm focal length and f/11.5.
I guess I didn't need to be too concerned.
Yeah, it could use more tweaking, but hey, it's first light!
Takahashi Mewlon 210
ST-8XE
Takahashi EM200
4 x 10 minutes L binned 1x1
Subframes added, 2 iterations of L-R deconvolution in CCDSharp, levels, curves and cleanup in Photoshop CS. Cropped and resized in IrFanView.
I have not given up on the AP reducer yet - the NGF-S SCT-focuser adapter has a light shield that intrudes into the focuser drawtube. I just ordered a version that does not have the light shield. Hopefully this will give me the in-focus travel I need to achieve focus.
Comments? Suggestions (other than the obvious - more exposures!)?
Bigger image can be seen at http://members.nuvox.net/~on.aunt/DSO/M51Mewlon.jpg
CS,
Eric
ST-8XE
Takahashi EM200
CS,
Eric
