I have had two set ups for a little while now. One primary imaging set up and one wide field DSLR set up. I get a set of frames started on the main set up, then when that is going, I set up the DSLR. This session in March was the first time I shot the same subject with both set ups. The first image is NGC 3628. The downside is that I had a bout a 30F degree change from focus to final frame - it's amazing the impact that can have on focus. Image as well as exposure and processing details are at:
http://www.jthommes.com/Astro/NGC3628.htm
Scope: C8 at f/8
Camera: Artemis285, Astronomik LRGB filters
Mount: G11/Gemini
Guiding: Megrez 80 mm at 555 mm FL, DSI Pro, PhD guiding
The second image is a wide field of NGC 3628 which is of course more popularly known as the Leo Trio galaxy group. Image and exposure / processing details are at:
http://www.jthommes.com/Astro/DSLR/LeoTrioWF.htm
Scope: Zenithstar 66 mm APO at f/4.8
Camera: Canon 350D (Baader ACF modified)
Mount: Celestron CG5 Advanced Series
Guiding: Home made 180 mm FL guide scope, DSI Pro, PhD guiding
Scope: C8 at f/8
Mount: G11/Gemini
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
