Last night I went after the emission nebula NGC 7822 in Cepheus and which forms an impressive pair with Ced 214 to its immediate south. The 7 to 8-day old moon was present doing its usual dirty work and I used the opportunity to capture some h-alpha data (12x20 min) using Baader's 7nm h-alpha filter and my Tak FSQ-ST10XME combo.
Due to a slight miscalculation on my part, I did not complete the RGB portion since the camera came very close to the pier and, as such, I only have the monochrome h-alpha version at the moment (the outstanding RGB portion will be acquired this evening).
NGC 7822 is quite impressive with lots of nebulosity and fine detail. The attached sample is approximately 50% of the original. I have never been a fan of scaled darks and I had no choice but to pursue such a calibration for the purposes of this temporary result. I will make sure I produce a suitable master dark over the weekend.
Further details available at http://www.perseus.gr/Astro-DSO-NGC-7822.htm .
Anthony.
Anthony.
