Ok, let me have it!
Started by eafrica, 02/18/2007 05:02AM
Posted 02/18/2007 05:02AM Opening Post
Hi all,
I've been battling with this image for a while now, and perhaps it's time to take a step back and let everyone take a look at this and see what could be improved.
I finally got around to adding color data to my Rosette Nebula H-alpha image. I've added 3 hours of RGB (12 x 5 minutes each channel, binned 2x2) to my original 4 hours of H-alpha.
I don't know if I'll ever bin my color data again. What an adventure it was, to say the least!
All data was captured last November, 2006.
Takahashi FSQ-106
Takahashi EM200 Temma 2
SBIG STL-6303
Astrodon HaRGB filters
My biggest challenge was aligning the stars so they don't end up with uneven haloes. A few tricks helped along the way. I'm still not 100% satisfied, but I thought I'd share for feedback.
Eric
eafrica's attachment for post 35828
Posted 02/18/2007 09:49PM #1
OK, I cleaned it up a bit to dare post a full-sized version. Here it is:
http://tinyurl.com/28bads
Eric
Posted 02/18/2007 09:51PM #2
A nice & very dramatic looking shot! 8)
Nicely done my friend! I like it! wink
Love the wide field around the Rosette, as it makes it stand out...
Posted 02/18/2007 11:58PM #3
Eric,
Looks like the detail was well preserved from the mono version and the color looks good. Your only challenge was alignment and haloes?
Do you use a full scale, offset, rotate, skew allignment program like Registar or Astroart - if so, shouldn't have so much of a problem. If you manually choose alignment stars, do you choose small isolated stars well off the edges?
I do a lot of 2x2 bin on color data. If you want to minimize your haloes, try selecting the medium to bright stars and running a minimum filter on them in the RGB's combined prior to adding any luminance or luminance layering. The 2x2 bin can bloat larger than your luminance - particularly if the luminance was an HA. Don't worry if you over minimize - worst it does it take your brighter stars to white (which they are likely to come out as anyway being bright).
My 2 cents worth...
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
