Shane Yarnall
LDN 1622
Pictor 201XT help
Started by Jacob.Glower, 06/24/2007 01:21AM
Posted 06/24/2007 01:21AM Opening Post
Got a question for anyone who is using a Pictor 201XT. When you're trying to focus on a star, does the brightness indicator change easily or does it stick on 00?
I 'accidently' used a reverse-wired 12V adapter for my Pictor when I first powered it up. (I didn't know anyone ever made a reverse-wired wall transformer let alone what device this came with. It's also probably dead now.) Since then I have only been able to get a star brightness of 34 (non-changing) or 00. Everything else seems to work OK - but I can't get the star brightness to change.
Since I never used a Pictor prior to this accident, I'm not sure if this behavior is normal or indicates I fried something.
Thanks in advance!
Jake Glower
Fargo, ND
Posted 06/24/2007 02:09AM #1
What scope are you using to guide with? When I set up with an 8" SCT I have to find a bright star like about 3 rd mag or brighter. Set to 3 - 5 sec snap shots. Use a 25 mm eyepiece and pull it slightly to get focus and center the star (the eyepiece varies how the focus works out). You need to get a value of 60 or more to work well because when you start the guiding the level seems to drop a little. Centering the bright star on the small chip is the hard part and focus is equally as difficult. With enough perseverance I have actually made the 201xt work and track all night. The 0,0 3,4 is there because your star is not focused or not bright enough.
Good luck.
Phil
Kennewick, WA.
AP 152(old blue)on CI700 w/80mm f/11 guider, C-8 on forks w/80mm f/5 guider, 20x80 binos, ST5C, 201XT, Ricoh 35mm, 20Da.
