The Elliptical Globular - M19
Started by jthommes, 08/01/2010 12:09AM
Posted 08/01/2010 12:09AM Opening Post
Not a particularly notable image, but I did catch M19 in a rather large field. It is generally not the appropriate image scale for a globular, but I do think the larger field serves to illustrate the asymmetry of this globular. The image is at:
http://www.jthommes.com/Astro/M19.htm
(you can click on the image for a higher resolution showing the cluster a bit larger.)
Scope - Explore Scientific MN152 at f/4.8
Camera - SBIG ST8300M (Astronomik 1-1/4 inch LRGB filters)
Mount - G11/Gemini
Guiding - Megrez II at 555 mm FL, DSI Pro, PhD Guiding
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 08/01/2010 04:28AM #1
Wow that's gorgeous! Congrats.
Please compare and contrast your experience with the ST8300 vs the Artemis camera. I have considered the 8300 myself, especially since my Atik 16HR is giving me issues.
Best,
David
Posted 08/02/2010 04:41PM #2
Sweet shot Jim! I always like your processing on globs.
Cheers,
Tyler
Posted 08/03/2010 04:00AM | Edited 08/03/2010 04:02AM #3
Tyler, David,
Thanks for the comments.
David,
I still have and use my Artemis285. The Art is interline and the 8300 is full frame. The 8300 wells are smaller though. So I kind of expected an increase in signal level based on full frame, but a decrease due to smaller well size / capacity. I think that a sensitivity comparison is about a push. The 8300 has a higher number of warm pixels than the Art with the Sony chip - I expected that.
So far, I have been using 1-1/4 inch filters on the 8300 - its not bad. The vignetting is not too bad (but I have mounted the filter wheel as close as possible). A flat set or even a pseudo flat works well - most of my images on the 8300 have not been cropped beyond a few percent needed to eliminate where RGBs are not aligned on the edges.
I also do some work with a DSLR. I found the 8300 to be a little like the DSLR except for the Mono data aspect (and, of course, a significant increase in sensitivity and S/N). The back focus is shorter than the DSLR (even with filter wheel) but longer than the Art.
Overall, I am pretty happy with the 8300. It is the first camera I reach for. I will use the Art or DSLR on a second setup while the 8300 is pumping out data on my primary setup.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
Posted 08/04/2010 12:15AM #4
Posted 08/06/2010 04:36PM #5
That is a good scale - gives you that "lost in space" view. (Color "looks" right too.)
Charlie
Darkness - typically 6.5+
Focus - JMI Smart focus
