RICHARD COFER
VDB 142
Started by eafrica, 08/04/2005 01:47AM
Posted 08/04/2005 01:47AM Opening Post
VDB (Van den Berg) 142 is a dark/emission nebula that is a small part of the larger complex nebula IC 1396 in Cepheus.
Ever since I saw its haunting yet captivating shape, I knew that I wanted to image this object. From this perspective, it looks either like an Elephant Trunk, which it is sometimes referred as, or a gnarled tree root, or perhaps some mysterious hooded figure emerging from a mist. A Nazgul or Ring Wraith, from Lord of the Rings perhaps (http://www.alleycatscratch.com/lotr/Nasty/RingWraith.htm)?
Imaging details:
Takahashi FS102
Astro-Physics 0.67 Telecompressor
Takahashi EM200 mount
Imaging camera: SBIG ST-8XE
CFW-8a filter wheel with Custom Scientific H-alpha filter
Guide scope: Borg 76ED
Guide Camera: SBIG ST-7E
Robin Casady 14" Tandem Bar
8 x 20 minute images
Calibrated in CCDSoft
Combined in MaximDL
2 iterations of Lucy-Richardson deconvolution in CCDSharp
Levels and Curves in Photoshop CS
This is my first attempt at imaging with a separate guidescope. I can't say enough about the Robin Casady Tandem bar. There was no differential flexure visible at all. Narrowband imaging just became a lot more feasible for me.
A small image is attached. A bigger version can be found here: http://members.nuvox.net/~on.aunt/DSO/VDB142Big.jpg
Comments and suggestions welcome.
Thanks for looking!
Eric
eafrica's attachment for post 25890
Posted 08/04/2005 04:38AM #1
This is one of my favorite objects too. You did a nice job!
Cal
Posted 08/04/2005 02:53PM #2
Thanks, everyone! I dabbled in H-alpha imaging last year, and was never satisfied with the results I got. This year, I decided to go for longer exposures at a faster f-ratio (the FS102 with the 0.67 reducer was theoretically at around f/5.5). Results are promising. Now, to save up for an O-III and S-II filter wink
Eric
Posted 08/05/2005 02:54AM #3
Eric,
You have captured great detail in this portion of IC1396. I have an old (early) image of this object. Your image makes me want to go back and try it again. Thanks for sharing.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 08/05/2005 07:13PM #4
Well done, Eric. Even the large image looks good.
Are you the luckiest guy in the world? Your first time with a separate guide scope and you didn't have flexure issues. Where's the sense of accomplishment there?
dan kowall
Posted 08/05/2005 11:23PM | Edited 08/05/2005 11:23PM #5
What a beautiful object, and so nicely imaged.... thanks for sharing it with us!!
