vdB132 and NGC6914; Cygnus
Started by tvdavis, 07/11/2007 04:19AM
Posted 07/11/2007 04:19AM Opening Post
I thought I'd give this region a try because of its complex clouds and color. I thought is would be relatively easy, ya know, blue clouds in a red field. I was wrong. I find this region to be very challenging to process without messing up the color. In fact I'm not sure if I even succeeded. The blue region is almost completely invisible in the Ha. All its details came from the RGB. Maybe I should add some clear filter data to this sometime...
http://www.tvdavisastropics.com/astroimages-1_00000b.htm
I should double my exposure time but I'm restless -- time to move on!
Tom Davis
Inkom, ID
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
Posted 07/11/2007 12:21PM #1
Tom,
You're right-that is certainly an interesting area to look at with the combination of nebula types. I love it when someone tackles the less imaged stuff! And, as usual, you did a terrific job. Actually, my reaction after looking at the Ha alone was that I feel you could actually bring that data up a bit in the HaRGB. I thought the Ha was a wonderful image in its own right and a bit lost in the final. The blue was really quite stunning on my laptop.
My two cents on an already wonderful shot.
Larry
Posted 07/11/2007 04:07PM #2
Very nice, Tom! I see how the reflection nebulae disappear in the H-alpha version!
Eric
Posted 07/17/2007 04:35AM #3
Hi Tom,
Well done. I took a look at an old image I had of this area and I can see I really lost out on the blue reflection. I like your idea of adding a clear channel, but it seems that your rg"B" data did pretty well.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
