Hello guys,
eventually I was able to mount my new h-alpha filter on the TEC180
I ordered a custom Solar Spectrum filter in Dec 2006 and I received it about a month ago. As usual, after receiving it either rained or the sun was blank so I could not use it. Today I saw a little opening and decided to put it on, regardless of the seeing conditions.
The technical specs are the following:
Research Grade
46mm clear aperture
0.3A bandpass
C-ERF Baader 180mm
I can use it at 2520mm focal with a 110mm mask to bring the F ratio to 23. At this focal length, given the 46mm aperture I can take the whole disk (provided the CCD chip is large enough).
With the full aperture I have to increase the focal length to 5000mm (approx.) in order to keep the F ratio above 23-25 which the perfect working condition for these filters.
I took this image today (and many others) at 5000mm even if the seeing wasn't very good.
I hope to test it in better conditions soon
Ciao
Luca
PS image is reduced to 80% quality and size to fit the size requirements
Research Grade
46mm clear aperture
0.3A bandpass
C-ERF Baader 180mm
Ciao
Luca
www.amun-ra.org
Solar Imaging Website
