advice for focus and color processing
Started by girard35, 05/13/2004 07:35PM
Posted 05/13/2004 07:35PM Opening Post
This my first attempt for saturn wind and atmosphere were definetly a factor with this but I think most of you would be able to better. I am having a hard time focusing on my laptop I can'ty seem to get good definition I using a 10" reflector f/5 a 2x barlow and Toucam Pro 840 this was 137 of 1300 stacked with Registax
Thanks for any comments
Rich
girard35's attachment for post 15883
Posted 05/14/2004 03:20AM #1
Rich, not bad at all for a First Try!
Focusing is the most critical & the most TIME CONSUMING procedure when capturing images...
SEEING could be part of your problem too, as BAD seeing could prevent you from reaching GOOD focus...
I normally set my webcam for higher frames per second (like 15-30fps) so that the image will reflect focusing changes faster. And after going IN & OUT of focus several times to get a feeling for the RIGHT position, I then change the frames per second to 5-10fps for higher quality capture...
Hope this helps a little,
Clear skies!
Ivan
smile
