Iris Nebula
AutoGuiding LX200 - To PEC or not to PEC?
Started by SJJindra, 04/28/2004 05:30PM
Posted 04/28/2004 05:30PM Opening Post
I am new to astroimaging (just posted my first picture) and am learning my camera, mount, scopes, and software.
I have an LX200 fork mount adapted to mount an FS-78 on top and a Celestron 9.25" SCT below. My camera is a SXV-H9 with autoguider. It is mounted on a 6" pedistal and Meade Super Wedge in my back yard.
Without PEC or guiding with a 3.3 FR (around a FL of 800mm) I took a series 120 - 20 second images of M104 with 2x2 binning. Of these only 20 (1 in 6) were decent, without star trails.
Later I set up the guider on the SCT at FL of 800mm and used my refractor at FL of 630mm for imaging. I took a series of 65 - 1 minute images with 1x1 binning. Still no PEC set. About 1 of every 2 images were decent, without star trails. I used the settings from the MaximDL/CCD guide test routine.
My question: should I set up the PEC for my mount in conjunction with the autoguider or just use the autoguider without PEC? Of course, maybe I am just being too PECky (pun is intended). Any suggestions on getting the most out of my LX200 mount are appreciated.
Thanks
Steven Jindra
Posted 04/28/2004 07:49PM #1
PEC is used to record and then compensate for repeatable errors inherent in all drives. For most fork mounted SCT's this is around a 4 min period (Depends on your gear set in RA). So for short 20 second - or even 1 minute exposures - PEC would not do much. IMO even "auto guiding" probably wouldn't add much - especially at low FL - to be worth it either at those exposure times.
Posted 04/28/2004 10:35PM #2
hi,
Use PEC .. get good pec training with the Lx200 and use it in conjunction with the autoguider you will get better resluts.
Larry Citro
Posted 04/29/2004 01:31PM #3
Any way you can post a picture of your setup? Sounds interesting.
Ralph
