I have seen some beautiful pictures taken with the Canon 10D and was wondering if anyone was doing similar work with the Nikon D100? Would anyone be willing to compare these two camera's and the D100's potential for astrophotography? Also is anyone using the Canon Digital Rebel? How does the "Pentaprisim" in the finder of the 10D and D100 compare to the flip mirror in the Rebel, do these move when the picture is taken like the flip mirror or are they fixed? Can they be locked up before taking a picture like some of the film SLR's?
Canon 10D and Nikon D100 comparisons
Started by Craig Burlette, 12/30/2003 04:37AM
Posted 12/30/2003 04:37AM
Opening Post
Posted 12/30/2003 03:46PM
#1
Craig,
The D100 uses a traditional CCD detector (the 10D uses a CMOS) and from the results I've seen, is much noisier than the 10D.
The Rebel uses the same (or at least very similar) sensor as the 10D and seems to have similar capabilities.
The Rebel has a pentamirror system rather than the 10D's pentaprism. This is not in the imaging train and does not move...it only puts the image from the focusing screen in the correct orientation and size in the viewfinder.
The Flip mirror is what protrudes into the imaging train when an image is not being captured. It reflects the image from the lens to the focusing screen which is what you see (via the penta-mirror/prism) in the viewfinder. When the camera is ready to take an image, it flips this mirror up and out of the way, so the light goes directly to the CCD sensor from the lens. This creates a small vibration. The 10D allows you to lock this up and out of the way before you take an image, allowing time for the vibration to dampen. The 300D does not have this capability.
For long exposures, this isn't a major issue, since the vast majority of light comes in after the vibration has dampened. For Lunar and planetary images, I've found that using mirror lock-up was slightly sharper than without using my 10D.
Rick Krejci
Rick Krejci
Funding Member
