Hi all,
I thought about posting this in the canon and/or the digital camera forums but no one ever goes there, so here I am. I've been experimenting with a Digital Rebel and a TV 85, piggybacked on an 8" SCT. I'm using a standard televue camera adaptor to connect the scope and camera. How do I determine what the magnification is at prime focus, and also how do I know what the field of view is with this setup? As I understand it, the Rebel has a 1.6X multiplier in effect . . . does this increase the effective focal length of the TV-85 by 60%, and if so does it also reduce the field of view by this much as well? I'm not complaining, just curious, as I find the field of view to be quite large as it is. Do I simply use the old formula of "whatever lens came with the camera" and divide that by the focal length of the scope? Normally that would be a 50mm lens, but in this case, the kit lens is an 18--55mm zoom. If I haven't confused you too much, any help is appreciated.
Regards,
Jeff
Regards,
Jeff
