VDB 142 Elephant Trunk HOO
Help, what's up with this? Tak90+DSLR problem
Started by ivanong, 01/28/2005 06:31PM
Posted 01/28/2005 06:31PM Opening Post
Hi all, need your expert opinion. Shot this test shot under very light polluted skies. Here is my imaging train:
Tak Sky90>Camera Angle Adjuster>Focal Reducer>IDAS LPS 2" filter>Wide Mount+T-ring>Canon 20D.
The left photo is adjusted in photoshop, but the right one is the left photo cranked up in contrast. Note that the field of illumination is very strange. There even seems to be a horizontal stop on the lower edge.
ivanong's attachment for post 21836
Posted 01/28/2005 08:07PM #1
Ivan,
It could well be two different problems. The round contrast is probably vignetting. I think (despite my middle-aged eyes) I see elongation on your stars in the corners on the edges, all pointing to the center. Also, the more you stretch the more you'll see the uneven lighting occur. I get it with my 3.3 FR on my 8" SCT. Plus you're trying to cover a very large chip on a DSLR. Have you tried to shoot flats? It's pretty simple to do and can work wonders. Some software also enables you to do artificial flats (eg: AstroArt). The lower black bar seems to be more of an obstruction. Anyway, that's my guess.
Hope it helps,
Larry Durst
Posted 01/29/2005 12:09AM | Edited 01/29/2005 12:11AM #2
Ivan, I too have had this problem. I finally decided it was my 3.3 Focal reducer. I did some testing the night after I shot the attached image with my st7xme through my lx200 and found that it only showed up when using this focal reducer. When I used my 6.3 focal reducer, it didn't show up in the images. Unfortunately I didn't save the test photos.
This is a raw luminance 1 minute exposure.
Hope this helps
Wayne
Melnmarn's attachment for post 87562
[COLOR="Blue"]Wayne[/COLOR] 8O
_________________________________________________________
Never stop looking up!!
Takahashi TAO-130on a Losmandy G-11 Gemini 4
Williams Optics Zenithstar 105 APO on a G-8 Gemini 4 (Field setup)
ST2000XM with CFW10/L-R-G-B-Ha-SII-OIII filters
Home Built backyard Observatory
Understanding Wife.. 8)
