Hello everyone,
for all you guys using lumenera cameras out there, I found out there is an easy way to take advantage of the 12bit mode capturing option even for Registax users. In fact I thought and said until today that capturing a 12bit .seq file to translate in avi was a waste of disk space, since avis are limited to 8bit and all the tonal richness of the 12bit would get lost in the translation.
I had a exchange of email with Cor Berrevoets to report a problem I encountered with Streampix avis (again the new 3.20 release needs Virtualdub re-processing) and he told me that one could use the translation into PNG files to exploit the full 12bit of the seq files. I've tried it and it works great! So now you can export a seq file into a bunch of separate PNG files and then drag them into Registax (very important: DO NOT SELECT THE FILES FROM THE SELECT MENU, BUT JUST DRAG THEM INTO THE GREEN INITIAL SCREEN AND REGISTAX WILL DO THE REST!). Using this method you can even circumvent the "2 Gb limit" problem since you can process up to 10,000 frames this way.
Just thought it could be useful to someone out there.
Ciao all
Luca 8)
Ciao all
Luca 8)
www.amun-ra.org
Solar Imaging Website
