Jupiter 05/01 Taming the Beast!
Started by agonggo, 05/01/2005 03:04PM
Posted 05/01/2005 03:04PM Opening Post
After days of trying to tame the C11, I was really about to give up on it and go back to the C8. I had been frustrated by the fuzzy images of this scope! After taking down the JMI focuser, I realized that the 1/25" adapter that came with the NGF-CM isn't perfectly flat and is tilted when I attached this to my Maxbright. I removed the 1.25" adapter of my AP130 and viola PROBLEM SOLVED!!
Seeing was 9/10 tonight with 5/5 transparency. The image of the right is a stack of 465 frames out of 500. I had to keep my exposure time low to prevent movement. I am still trying to figure out how to remove the vertical lines when you look at Jupiter at close range. These disappear though when you look at the image about 2 ft away. Would appreciate it if I can get advises on how to deal with this
Jupiter is filled with details! The Oval BA is very prominent at the STB with ovals around it. The red spots on the NEB are very resolved and so are countless of rifts! There is a long dark red feature on the NNTB.
More info at:
http://jupiter.cstoneind.com
Regards,
Chris
agonggo's attachment for post 23855
Posted 05/01/2005 03:08PM #1
Lots of detail in that great shot Chris. I'm not sure about the lines. I have seen them on other images. Could they be interlace lines? Vince
