Taken in below average seeing 1 hour past transit, 25deg altitude, in between trees. The 2.5x barlow was too much magnification for the adverse conditions, so I went with the 1.8x. 30fps R,G 15fps B, best 150frames each stacked. Having just spent the previous 2hrs getting perfect drift alignment with my 2.5x barlow, I realized that while essential for deep sky imaging, perfect alignment is not desired for planetary shooting. At least not one with a scope with dust motes. Even subtracting out flat fields did not prevent artifacts ending up in the final image. Next time I will crank the base mount handle exactly 1 turn to achieve a "uniform" drift across the chip as I collect the avi. I used 800gain/140gamma for this image but will try 900/130 next time. Unfortuneately I only have 16min between trees. It was my first RGB Jupiter and leaves plenty of room for improvement.
Regards,
Steve
Regards,
Steve
