Shane Yarnall
LDN 1622
K3CCD Help Needed
Started by Brad, 08/10/2003 03:53PM
Posted 08/10/2003 03:53PM Opening Post
Anyone who knows K3CCD pretty good available to answer some questions from a newbie? I started out with the tutorial but ran into problems about half way through.
I'll start from the beginning today and try to determine where I messed up. But may need a little help if I get hung up again.
First of all, the tutorial uses images obtained using a SC modified webcam, and has quite a few hot spots and also needed flat screen correction. Is that a factor when doing imaging of bright objects with a unmodified camera?
Brad
Posted 08/10/2003 04:24PM #1
Hi Brad,
For imaging bright objects such as planets / moons using the unmodified camera, I don't think you need to apply the dark frame / flat field correction.
btw, which tutorial are you looking at?
regards,
Jeff
