Ahhhh... finally a generous FOV and low f/ratio, opening a path to large diffuse targets that previously eluded me. Hallelujah, I can see!
I've corrected the prismatic flaring present in the prior night's images (the chromed end of the 2" adapter was the culprit), and have started to process the images taken last night.
Leading my list of "gotta gets" was M31 as it crossed high overhead. Target at 12 o'clock high, clear skies, a crescent moon below the horizon, and no skunks or other critters hanging 'round... ahhh life can be so sweet! Here's the M31 shot (be gentle with me... this is just a 4 inch scope and consumer grade digicam
The Flame/Horsehead area shots are on the back-burner, as I zigged when I should have zagged at Alnitak, making for a veddy veddy poor job of framing the intended area. If I weren't so cocky, I would have checked one of the shots BEFORE embarking on a fourteen image toot!
My Encounter with Saturn was a washout, as one of the ToUcam drivers was missing on my laptop (probably got trounced when I loaded DVD drivers). I've since reloaded the software and am now ready to give it another go... not tonight though, my arse is dragging!
Cheers,
Paul
Image info is at: http://www.astro-nut.com/m31.html
Cheers,
Paul
