Mars f45, 1/18/08 first DMK21
Started by fugardi, 01/22/2008 06:28PM
Posted 01/22/2008 06:28PM Opening Post
Last Thursday night under bad seeing and frigid temps, I tried my new DMK21 USB camera with a double barlow stack (2.5x inside 1.8x)and my C11 Compustar. I did not use my lymax cooler or any observatory fan, plus I stayed inside my dome while I imaged. Under poor seeing, I was mainly trying to debug my new setup not expecting much and captured 1min of each R,G,B at 30fps. I noticed that the blue brightness dropped off significantly and had to go to 15fps. I left the brightness & gamma at the default settings, but will try to boost them next time out. Hopefully, with better seeing I will be able to post a decent Mars before its too late. Of course I should have bought the camera a couple months earlier...
Regards,
Steve
fugardi's attachment for post 40565
Posted 01/22/2008 07:32PM #1
Hi Steve:
That's smart to do a practice run before good seeing moves in, it looks like you already have the RGB figured out very well. Good luck, I look forward to your future postings.
Take it easy, Dan smile
