With lousy conditions, this was my first attempt at Mars since 11/8. CSC & weather.com predicted clear and avg seeing until 3am, with the Mars transit at 1:43am, it should have been a perfect night. Unfortuneately, I spent too much time collimating my f45 double barlow stack against my artificial star, then started to experiment with different filters and gamma settings. After finally deciding to try my new IR+UV filter at 12:51am, I noticed the brightness dropping off so I just kept increasing the gain, after 2300 frames, Mars practically disappeared, and as I looked up at the sky, clouds were everywhere. 2hrs early! Never again will I cut it that close. Anyway, I managed to stack 100/2300 frames from my 2.5x inside a 1.8x barlow stack (with the 1.8x inside the 2.5x the glass touches). I used my C11, Toucam IR+UV filter, f45, 10fps, 1/25sec, 50% Br, 0% Gam, 40+/-%Gain, 100%Sat, 24/24 on the Red/Blue color freeze. I should have taken a new flat avi with this setup. Next time out I will get a few avis captured before trying new things. My temperature sensor battery died so I did not get the mirror delta T. There is still plenty of time to capture the red planet and its growing size is impressive. Good luck
Regards,
Steve
Regards,
Steve
