mars image 15th July 2003 1941UT
Started by weileong, 07/15/2003 11:15PM
Posted 07/15/2003 11:15PM Opening Post
Dear Friends,
The skies weather here has been cloudy most of the time for this month and this morning I managed to steal a few minutes when a small clearing occurs thru the clouds which allows me to image for about 30mins.
Seeing was 5-7/10 and transparency 4-7/10 (thin high clouds)
As usual the images are done with the 250mm Takahashi mewlon @ f/67.5 with the Televue 5x powermate + Philips Toucam Pro and the Baader UV-IR blocking filter. I've experimented with a combination of televue 2x+1.8x barlow for a lower F ratio in the region of f50 which I will process the AVI and send them out this evening.
Best Regards
Wei Leong
weileong's attachment for post 7623
Posted 07/16/2003 12:27AM #1
Great Images!!!
TanWei
WE've been under the clouds for the past 6 weeks....other
than 2 days at the full moon!!!!!
Hurricane has passed...
Let's get some images!!!!!!
We hope to produce images of this caliber close to late August....
Regards Preston in Houston Texas
Posted 08/08/2003 08:06PM #2
Hello Wei Leong,
I very much appreciate your Mars image and your technical capture information. I am now in the process of getting a laptop and Philips TouCam Pro working. To make a long story short I have discovered it takes more processor power/speed and RAM to run a webcam than I thought ;o)
May I ask you where you obtained your Baader UV-IR filter and if you have any links for more information about it?
Thanks again for the beautiful Mars image and information.
Bob L
