My first Uranus capture
Started by RedIrocZ-28, 09/26/2006 03:13PM
Posted 09/26/2006 03:13PM Opening Post
I normally post over on cloudynights.com but I thought I'd pop in here and post up my image of Uranus captured last night.
Most of the guys know me on Cloudynights as one of the Dob imagers, I have no tracking ability. I just point the scope in front of the planet I am imaging, and let the planet fall through the Field Of View as I record with the ToUcam. I use a Celestron 2x Barlow lens removed from the Barlow tube, and screwed into the ToUcam's Mogg adapter, I then stick this into the Celestron Ultima 2x Barlow. I figure that It is anywhere between 3x - 3.3x based on many peoples thoughts that the Ultima Barlow is really a 2.3x Barlow.
Needless to say, I am very happy with my first image of Uranus. Now, if only I could capture Neptune and perhaps Mercury I would have all of the Major planets captured without tracking! Then I could move on to imaging with an EQ table like Mike Salway. smile
RedIrocZ-28's attachment for post 33672
Posted 09/28/2006 09:38AM #1
Hi Brad,
A good image for your set up. Have you checked out the ALPO Japan website there are quite a lot of Uranus images being posted there recently. There are not too many unguided Dob imagers. My set up similar, but I use a Sony handicam aimed down the eye piece. I have a ToUcam still in the box unused and an equatorial platform under construction. One day soon I will finish it. Mike Salway started out same as you and he's doing some nice work now with a DMK camera on equatorial platform. It would be nice to see your completed set of planets.
Mike Ashburn
Posted 09/28/2006 03:31PM #2
Wow! It's surpisingly good for an unguided image.. thanks for sharing... KMM
Posted 09/28/2006 04:27PM #3
Brad, you must have incredible patience! Just to be able to get Uranus in a Toucam field of view at 500x without a clock drive is remarkable, let alone imaging it for several minutes. Nice shot. I wish I had your level of patience, thanks for posting
Regards,
Steve
