Shane Yarnall
LDN 1622
Omega Centauri
Started by astroguy, 06/10/2004 02:19PM
Posted 06/10/2004 02:19PM | Edited 06/10/2004 02:21PM Opening Post
After see some gorgeous images posted of this fine jewel in the sky I knew that there was something wrong with the image that I had put together. With the help of a friend I found that I had the Red and Blue channels mixed up. ( I know have a different filter wheel that I personally put the filters into and labeled them so this would never happen to me again)
I think that the little miss-hap and the end results are startling
RGB image 9x 480 seconds per channel
Tak FSQ 106
Taken WSP 2004
SBIG 10xe
You can make out 8 galxies in the FOV, if you want to look for them the larger image would make it easier
Here is a link to the image at 2.9 mb if you want to see this up close
Large 2.9mb
http://web.tampabay.rr.com/galaxyquest/CCD%20Images/N5139colorwebLarge.jpg
* If you are one of the lucky ones that can not get to the image by clicking on the link and get a forbidden message you can then click the goto button on your browser after you get that message and it should work or you can simply copy and paste the link into your browser and then hit goto and that should work too
astroguy's attachment for post 16618
Posted 06/10/2004 03:13PM #1
That looks wonderful, Mark.
My regards,
dan kowall
Posted 06/11/2004 12:44PM #2
Excellent image Mark!! Wonderful color!
Chris Woodruff
